I have my tv tore appart so i can read the part number off of my inverter board but i cant figure out which part is the inverter board. how can i determin which part is the inverter board?
SOURCE: Need a new MV-220 inverter board, but cant find it anywhere!
It may be worth a shot, but before you give it a go, I'd scrounge up any info you can on your florescent backlight (power rating, input frequency, ect.) Take it out carefully and see if it has any markings.
Then you can use a multimeter to test the output of the MV176.
If you end up ruining the light you have, you could always try and obtain the MV176's bulb and attempt to install it along with the inverter.
SOURCE: Sceptre x37SV-Naga inverter board part number is
4h.v1838.411 Picture
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj1926006130.jpg
4h.v1838.241 Picture
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj1926006140.jpg
The 2 boards are not exactly the same, the 241 does not have the small transformer installed by the first connector (as shown in the picture) and 241 is for AUOPTO LCD panel T370HW01 V.2.
The 411 has the small transformer on the board and it is made for AUOPTO LCD panel T370XW01.
It may mean that the pin-out of the connectors may not be the same. I would be real carefull about using the wrong board.
By the way, the fuses check out OK?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
SOURCE: troubleshooting screen inverter and backlight on acer 5738
You are right! the inverter is the likely problem, unfortuneately unless you have another screen there is no reliable way of testing, the inverter puts out at least 1000 volts and don't attempt to check with a meter it will probably get damaged.
SOURCE: Inverter board
Inverter board?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
715L1103 AOC IDPC7425A3 Power Supply for TFT1780PSA LM729
