tried to disconnect all the sources that have been hooked up to the tv that might cause of shut off. if still the same issue suddenly shut down, at this time you will need to check if their is a shorted in the inverter board for back light or power supply failure.if under warranty you can ask for assistance at the supplier to check the unit.
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug. If you are lucky it maybe just a fuse blown out. Thanks
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
