Washing Machines Logo
c
craig leister Posted on Jan 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung front load washer has loud buzzing during wash cycle
Also buzzes when the water starts right after I press the start button
Andras Decov
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jan 15, 2019
Andras Decov
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
71809
Points
17
Watet valve probly block or not enough pressure,take down the hose has to beca small filter probably need to clean from limescale
timoboon2
Level 2:
Sergeant:
  • Samsung Expert 360 Answers
timoboon2
Samsung Expert
Level 2:
Sergeant:
Answers
360
Questions
0
Helped
154542
Points
959
Contact Samsung support for this. They give free support all over the world.
5 Related Answers
Anonymous
  • 249 Answers
  • Posted on Dec 08, 2007
SOURCE: burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Anonymous
  • Posted on Dec 26, 2007
SOURCE: washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Anonymous
  • 351 Answers
  • Posted on Mar 04, 2008
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Anonymous
  • 26 Answers
  • Posted on Jul 30, 2009
SOURCE: Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 11, 2010
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
Samsung dishwasher makes a loud buzzing sound when the water is filling. It pulses a couple times to start then is constant. It pulses again right before the wash cycle. Comes from the bottom left.
This is common. The noise is coming from the water pump. If it bothers you, you can try UNPLUGGING the washer or turn off the Circuit breaker first. Then you can remove the bottom kickplate on the front of the washer and clean around the pump. If there is a water filter scree, clean it out. Make sure there is nothing rubbing against the pump which could cause a buzz. Tighten all fittings and screws to eliminate vibration noise.
My Gallery series Front load washer was making a loud buzzing noise and was not spinning. when i took my soaking wet clothes out there was a puddle of water inside. I tried the drain cycle and a new wash...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine.In this case you need to check the free running off the mottor manually, check the voltage on the motor,If absent the controller is a suspecct. check the capacitor of the motor. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Makes a loud buzzing noise when attempting to start cycle
The lock solenoid on the door latch assembly may be hanging up or just noisey. If washer starts and runs then all is ok. If washer wont start, just buzzes, then door latch assembly may have to be changed.
1helpful
Jul 30, 2009 • Dishwashers
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
It makes buzzing noise and doesnt work
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
click the link http://www.repairclinic.com/0088_11_1.asp#Level1_5
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
