SOURCE: frigidaire front load washer model LTF530DS loose drum
I have the same issue with the broken spider...in the us and they say it is $300 for labor and $360 for parts. My washer is only 3+ years old...what can I do?
SOURCE: drum/frigidaire washer
wow thats a long hard job ,,overhaul....the part your looking for is the spin tube surport,,you have to take the hold drum out than seperate the front tub from the back bearing tub,,and pull wash basket out though front..,,also if you had a leak or surport broke and is making noise.. change back bearing tub too.i recommend a professional technician...but if you want to do it your self ..post question how to change wash basket,,glad to help
SOURCE: front load washer wont spin
it must drain before it will spin.if water is standing in it .remove power take off frount panel.remove screws that keep pump onthe washer move towards bucket and open pump and clean out.God bless tom
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
SOURCE: Frigidaire front load washer model LTF2940FEO. As
if water on floor at base of machine,most likely the pump is leaking or the pump hose connections for drain pump need attention either replacement or clamp could just have woked itself loose.
