SOURCE: no remote control will it run without remote
Well the fuse is ok if it lights up. Could be a stuck button. The ac does not need the remote to make it go. press the mode button and move the lights to the cool selection and set the temp below 70. It should kick on. You might have to go a bit deeper. The next thing I would check is for a leaking capacitor. If it leaks then nothing will happen.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My toshiba 62hm84 was given
The remote control for this model is no longer available through Toshiba. You can operate the set but will not be able to use the picture size features. You should be able to work the main functions and also access the picture and audio on- screen adjustments. If you find a vendor that happens to have miscellaneous remotes, the remote number is CT90164.
I hope this helps,
Skyassoc
SOURCE: operating a panasonic dmr-ez47v without a remote control
Many DVD recorders need the remote for a few functions like menu and setup. The remote part # is EUR7659T80 in the US. You can order parts here . it costs about $35 US. Save yourself some headaches.
SOURCE: I need a remote control
What is the DVD brand and model?
Testimonial: "Cambridge Audio DVD53RW"
