I did some research on YouTube troubleshooting and it seem like the T-con board would probably fix it. While I was replacing the T-con board I disconnected and reconnected the ribbon cables to that board and seemed to have made the problem worse. Now I have a new board installed and I can hear the audio but the whole picture is distorted. I am trying to determine if it is the LED buffer panel which I am told it is not cost-effective to replace. If anyone knows how to be sure that it is the LED panel please let me know. Thank you! Stuart
SOURCE: Vertical lines in screen / Blurry pictures
Hi there, please check this link: http://www.imaging-resource.com/badccds.html Sony will repair your camera free of charge. Best regards, Arpi
SOURCE: distorted screen
u should ask other tech. they might have another solutions. And your tv is only 18 months old so ask ur company service man to repair it.. It might be in warranty period.
SOURCE: Traditional toshiba TV picture problems
it is due to poor focusing please check 1 set with focus control fitted on flyback transformer, 2 check focus control wire comes to crt base is loose or some foreign material deposited on it. 3 crt base loose contact. 4 if tv is old then there is a possibility of crt is getting weak. if you are not a technical person do not open set as tv has very high voltage inside. hope this will help.
SOURCE: Hitachi UltraScan HD... picture is way off and has red lines
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
SOURCE: Vizio 32'' VO320E Image Distortion
I hope not but:
this is probably a failure from the screen or the electronic parts that control the videosignals.
i think having a specialist or the tecnical service from vizio taking a look at it will be best and safest.
Hope this is helpful, and greetings,
Olivier.
