GTD65EB - if this was your actual model number line, which you seemed to be missing, you need to take off the shoulder 1/4 screw in the back on the control panel, then remove the control panel pushing away fromy you, then your remove the two philips screws located under the control panel, open the dryer door, then remove the two philips under the lid, then move the lid back and then remove the two shoulder philips screws holding on the front of the unit. then pull the front of the dryer towards you, then remove the dryer front by pulling up, disconect the door switch wire, and the lamp wire on the top if yours has a door lamp. make sure its unplugged before attempting, if you have issues call GE appliance service for repairs.
SOURCE: front panel removal
use a small putty knife move in 4-5inches from each edge of the frount push in the putty knife to the top release clip . it will feel springy when you have found the clip. push in the putty knife and pull out on the side of the panel, do the same process on the other side and it is loose
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
SOURCE: How to get the front panel off GE Profile Harmony
Here's a simple overview of what you have to do:
You actually don't remove the back sir, but that's okay, that's a common misconception for this model dryer. The proper way to disassemble this particular dryer is you start with the top. You have to start with the removal of the control panel, then the top of the dryer. What I would consider the top cover. Then you'll have to remove two plastic brackets. Then you have to remove the front. There's two aluminum brackets in each corner, remove those. Open the door and there'll be two more screws to remove on each side. You have to lift the front just a little and then pull towards you. I forgot to mention, before that part, you'll need to ensure you are disconnecting the electrical wiring. There's almost no chance of connecting the wrong ones even if you forget. GE made this part novice proof. Once you get the front removed, you'll see the lint/trap. There's a couple of screws on either side of the aluminum housing. Not much to it. Let me know if there's anything I can clarify further. Have fun!
SOURCE: How to remove front panel of dryer
Be sure to unplug the machine from the mains,
1.-Remove the top cover of the machine, very straight forward.
2.-Unclip the universal coupling from the main timer to the back of the knob.
3.- The whole knob assembly is held in place by a backing plate.
4.- There are 2 clips at the top of this backing plate raise them and the backing plate and knob can be pulled out.
5.- there is a plastic clips but be careful not to break it.
Your ffeed back and ratting are so important for me. thank you
Was this helpful?
The knob breaks when it has been turned in the wrong direction several times. It's a safety device so as not to damage the main timer.
SOURCE: Need to remove the front
Your service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
