SOURCE: NEED TO KNOW WIRING
i have been to fic's web site, i cannot find any mb labeled au31. do you have anymore information about the board, how old, which processor, what socket, which north bridge, south bridge, which model system, etc? however the pins are usually marked "pwr sw" or "pwr" and are usually with all the other front panel connector pins.
SOURCE: wiring
starting at the tail light harness coming from the truck, brown wire is for tail lights, black is ground, dark green is right turn and yellow is left turn, the turn signal wires are also the brake light wires. that sounds weird but if you hit the brakes and turn one of the signals on the actual brake light will blink. hope this helps you.
SOURCE: how to connect plugs of front panel in the main board?
the power switch connector goes vertically where it says pw on the pins at the bottom right of the board. there is a diagram in the user manual on page 23. you can download the manual fro their website.
Thanks
SOURCE: where does the cable go to on main board from MSI Geforce 9500 Gt
yes is for the fan you can cut the connector if the pins aren't allready next to each other. yel or red is allways + in a pc
SOURCE: problem with raptor 660
There is a manual available for you freebies:
http://www.carlsalter.com/motorcycle-manuals.asp .
And will help with any further work you do on the bike.
does the panel itself turn on at all, even for a split second. do you have sound?
