Computers & Internet Logo
Bernadette Mendiola Posted on Jan 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is it saying that I have a connectivity problem
Peter Dragonetti
Level 3:
  • Master 798 Answers
  • Posted on Jan 16, 2019
Peter Dragonetti
Master
Level 3:
Answers
798
Questions
Helped
209355
Points
2183
Try to run a network error scan.
Click on the icon next to the watch on the screen and choose network connections and there you find it.
My 8.9 lte I can not get on line but say,s I,m connected
When you say it says connected! I think you mean the tablet is connected to the WiFi but the WiFi is not connected to the Internet! Is your internet connection ok? Check all the lights are green on the router!
My Walkman NWZ-S544 connects but does not pass image that says walkman, and when I connect USB loads but says "the timer and alarm will become invalid," already did reset and still the same, that woul
It's supposed to say ")Connected USB)The timer and alarm will become invalid." I does that because it's charging when you plug it into your CPU. Hope this helped!
Where do i plug in my dvd player to a sanyo avm 2506
Get RCA cables they come in 2 or 3 conductors, Yellow andWhite for Mono and Yellow, White and Red for stereo connection.Connect the one side of the Yellow cable to where it saysVideo OUT on the DVD.
Connect the other side of the Yellow cable to where it saysVideo IN on the TV.
Connect the one side of the White cable to where it saysAudio OUT L on the DVD.
Connect the one side of the White cable to where it saysAudio IN L on the TV.
(optional) Connect the one side of the Red cable to where itsays Audio OUT R on the DVD.
(optional) Connect the one side of the Red cable to where itsays Audio IN R on the TV.www.aaatvservice.com
5helpful
2answers
I have a problem with my internet settings. I would like you to help me with my connection, because its keep saying the error code and then it has numbers, and also says unable to connect to the internet....
You have to go to your internet connection settings on the Wii, and load the user agreements, accept them, and connect to your wireless internet.
1helpful
Phone screen just say connecting
If is says connecting then most probably its not getting a connection from the base. It could also be your telephone line. Check if the line is active.
Please rate if helpful.
Thanks
My wi-fi says its connected but its not doing anything
I have an iPod touch 4th generation. It is doing the same exact thing. It says that its connected but when I try to go on the internet, it says it's not connected.
Airport says full connection to wireless router, not online tho
if it says you have a good connection, it means that you are connected to the router, though the router might not be connected to the internet. try powering off/on the router (leave off for 10sec.) to see if that corrects the internet connection issue.
Also, when it says that the connection is good, open a web browser and type 192.168.1.1 or 192.168.0.1 or 10.10.0.0 into the address bar (you can find this address by going to Network properties and looking at the Wireless settings. It should say "gateway" or "router". If you put that address in the browser it will pop up with the Netgear settings page if you have a good connection to the router. If so, then it's a problem with your router connecting to the internet and you might have to call your ISP/cable/phone company to get it fixed.
Compaq presario c300
If you're running a wireless network, make sure all computers on the network use the same network name, for instance "My network" Home Network etc. one can't say "MS HOME" and the computer you're using say "My Network"
Router problem
Hi .
First who is your service provider?
Can you connect to the internet if you directly hook your modem to your computer.
1>If so connect your Modem to your router on the colour code slot on the router which says modem
2>Connect a cable from the router to your computer
3>The lan light on the router should be turned on
4>Check wether your lan says connected . To check that click start-> control pannel -> network connections
5>If it says connected try internet explorer settings
6>If it says limited or no connectivity
Click start ->run -> cmd->ipconfig
7>It should say ip address as : 169.254.x.x.
8>If so type ipconfig/release
9>It shoul say ip address: 0.0.0.0
10>Type ipconfig/renew on command promt
12>Disable and enable lan
Let me know if this helped and also if you dont what kind of messages you get .
I have a cable into my laptop and it says I'm connected but Not!
Calling the ISP is the best solution as keefers said, but check if you need to use some dialer or there may be some connecting shortcut you need to double click to get connected or login to the ISP.
Grand Canyon Tech
Grand Canyon Tech
