SOURCE: How to play TV sound through Philips Mcd288
You must plug the t.v. audio out cables into an audio input on the philips. left and right audio rca jacks. then you must select that input on the philips to hear the tv. Lawrence
SOURCE: "Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
SOURCE: How do I connect external Bose speakers to Philips
can i connect more speakers to a cinemate bose
SOURCE: Hi.How can I connect SHARP HT-SB400 sound bar
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
SOURCE: HOW DO I CONNECT MY TOSHIBA TV TO A VIZIO SOUND BAR?
Take it back to where you brought it from, End get your money back. End get a sound bar with a optical jack on it,
