SOURCE: GE Bluetooth Transmitter - pairing problems
There should be a button on both the headset and the reciever. Y ou must hold them in intel they beep or start flashing.
Start with the transmitter first then headset.It may take a little playing around but you should be able to figure it out.
SOURCE: Power locked
Considering you have been patiently waiting for almost two weeks, you probably have found a cure by now.
If you have, please post it as a comment to help others.
If I had seen this before, I would have suggested pulling the AC plug overnight to see if it would reset itself; all modern sets are very complex making them prone to unintended actions of the kind we live with on our crummy PCs.
SOURCE: My Envision series AOC TV lights up, but when I
This is either a problem on the Power supply board that supplies the 24volts to the Inverter board or the inverter board my have a bad capacitor or two, or a bad transformer. It's difficult to say exactly without testing it.
SOURCE: How do I change the
Look for the manual control button the said INPUT.Pushes couple times,now u will move within HDMI modes like 1,2,3.
SOURCE: I have a 32" AOC Envision L32w761 LCD hdtv with no
need to ck for your 24 volts going to your inverter board if missing ck power supply
