SOURCE: How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
SOURCE: Manually turn on base heater, thermostat broken
you can jump your w terminal over to the r terminal for manual but remember that the unit will not cut off on it's own.
