Home Logo
Minka aire ceiling fan bottom lights won't work
One bulb was blown, but neither were working. I replaced the blown bulb but bottom light still won't come on. All other parts are working.
  • CJ Rock
    CJ Rock Jan 21, 2019
    Does it have two pull chains and/or a remote? Please post the model number, usually a label on top of fan housing.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Mar 31, 2008
SOURCE: Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Anonymous
  • Posted on Jun 28, 2008
SOURCE: Change Ceiling Light Bulb
See https://techinfo.honda.com/rjanisis/pubs/om/CR0202/CR0202O00285A.pdf
Pry the lens (the white part) from the rear near the two sides with a flat screw driver. Don't pry the ring/edge around it.Take the bulb straight out or pry it out. Press the new bulb in the slot and press the lens back on.
Anonymous
  • 4 Answers
  • Posted on Dec 29, 2008
SOURCE: Right rear brake light still out after replacement with new bulb.
You must replace the relay, yes, underneath the steering column. It's 47.00 at the dealer. I had the same problem. Should be fine after that!
Anonymous
  • Posted on Jun 29, 2009
SOURCE: no brake lights , everything else works
try playing around with the turn signal lever,push towards the dash.had same problem with 98 blazer,that is where your switch is located.
Anonymous
  • 123 Answers
  • Posted on Jul 31, 2009
SOURCE: brake lights not working, but middle brake light works.
Try cleaning the contacts with a wire brush if they appear dirty and then apply a small amount of silicone to the bulb contacts also try replacing the bulb as sometimes they don't appear to be blown but are
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
2answers
Minks aire mojo ceiling fan light will not come on
Try changing the bulb. Make sure the bulb is touching the connector in the bulb socket.
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
We have a UC9040T switch that stopped working after our power went out. Any suggestions?
I have minka aire uc9040t wall controller. If there is no green light make sure you have power to the controller wall switch. Mine had power but no green light, remove and disconnect the controller, open it up, remove the back plastic cover, you will possibly need to replace the internal 5 amp fuse that is soldered in. It is labeled on the bottom of the circuit board, and is encased in rubber heat shrink tubing. You will need soldering tools and skill. Mine was blown, replaced - works now.
My Minka Aire conceptII ceiling fan comes with a 100w bulb. where I can buy a brighter bulb?
most well stocked hardware stores will carry bulbs that are larger then 100watts -- or a specialty lighting shop will also have a higher wattage bulbs.
c...
1helpful
Minka Aire Como F603 - Light bulb burned out
I found the Manual to the F603 in pdf format at: http://minkagroup.net/Admin/UploadFiles/F603-English.pdf It describes how to put bulbs in so it was simply a matter of reversing the instructions to get the old ones out. However, it is not that easy to get the bottom section off so one has to be careful or you will twist the whole unit instead of just the bottom part..... I think what you did was push up too hard and then turn the whole unit. Try pushing up firmly but at the same time hold some fingers (or have someone help in this) on top of the bowl above the fan blades and then twist counterclockwise an inch or two and the bottom part will release (don't let it fall). Then you have easy access to the bulbs. Good luck.
Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
1helpful
2answers
Mar 11, 2008 • Dryers
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
