Typically it does this for about 30 minutes then will respond when the power button is pressed. It has been off for almost 24 hours now. It is plugged into a surge protector but I have tried the outlet directly and all of the recommended "reset" suggestions. ???? UPDATE: Solved. I found a similar issue and did one of the suggestions: unplug for at least 1 minute, press power button, plug in and release power button. Came on instantly. Thanks!
SOURCE: power outage=shut down
You do not say your location- so this may not be relevant to you. If in UK - check the power cord fuse. If it is a model that relies on an external power supply- try to find anther of the same specification. Other than that presume it has died
SOURCE: TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
SOURCE: no power
Unplug the tv press power on and plug it back in.
some of these units have a reset clearly marked on the back.
connect direct to wall as the surge protector may now have issue.
SOURCE: power outage then wont turn on
contact the power company to see what they will do for you they are responsible for power damage also the surge protection should have replacement warranty. may just be blow caps but take to a service center to have it looked at better yet have a service person come to your home to look into it.
SOURCE: 27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
do you get extension corn in Iowa?
