9 possible things to check per the web page below:
https://www.support.emea.zanussi.com/en-uk/Laundry/01_Washing_Machine/The_washing_machine_is_displaying_E10_C1
SOURCE: zanussi progress 1200 WASHER DRYER
This means that the filter is clogged. Get a towel (or two) in our case, and then unscrew the filter. It'll be full of lint.
SOURCE: zanussi washer/dryer zwd1471s
E20 normally means there is a blockage in the drain tube/filter. I have the same problem, but the drain tube is clear. I have searched the web and found the solution being down to the "plastic bottle-like condensor having debris/fluff in it".
SOURCE: e10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
SOURCE: My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
SOURCE: AEG Lavamat washer dryer, machine
Yes you need to change the cold water valve you dont mention the model so it will either be a 2 coil or 3 coil water valve. one of the valves responsible for the tumble drying condensing is faulty.
