Televison & Video Logo
Uriel Palacios Posted on Jan 13, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Programing Phillips universal control without a setup button to a westinghouse tv?
Level 3:
Top Expert:
  • Westinghouse Master 76,851 Answers
  • Posted on Jan 13, 2019
Westinghouse Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14995683
Points
237762
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}/
5 Related Answers
Anonymous
  • 21 Answers
  • Posted on Oct 22, 2008
SOURCE: Programing Code for RCA Universal Remote Control
It does not have any code.
Anonymous
  • 59 Answers
  • Posted on Dec 12, 2008
SOURCE: I need codes for a phillips tv and a phillips universal remote?
Hi michaeljlent,
There are a number of codes for your remote that correspond to Phillips TV models. They are:
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
For your reference, here's a web address where all the codes for your remote are listed (along with programming instructions):
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
Anonymous
  • Posted on Dec 26, 2008
SOURCE: Teknique Jumbo Universal Remote Control Instructions
Pacific TV - Press "SET" and Hold it, press "TV" and release it, then release "SET", then type one of these codes 0676, 0677, 0678 or 0679. After each code try powering off the TV using the remote. One should work. (I think the 2nd one worked for me).
Anonymous
  • Posted on Apr 14, 2009
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Anonymous
  • Posted on Feb 03, 2010
SOURCE: I am having problems programing a universal remote
urc-386-remote.blogspot com
URC-386 HRS-GLOBAL
URC-386 Universal Remote Control
http://urc-386-remote.blogspot.com
Would like to know what the code is to program my GE universal remote to my 2008 Westinghouse model number ltv-37w2hd
Be sure to manually turn on the device you wish to control. Press. And hold the setup button until the red indicator light remains on and then release the button. Press.
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
How to setup phillips universal remote to a panasonic tv
More items...
Finally I was able to get the universal remote to turn the Samsung TV on and off, but nothing else. We need a little help here, ok?
the code must be accepted for it to turn on and off
that may be all that remotes code can do on that TV
try this phillips support site
Universal Remote Control Code Finder
form another Phillips site
  • Turn on the device (TV, DVR, etc.) you wish to operate.
  • Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  • Press and release the desired mode button (TV, DVR, etc.).
2answers
Phillips universal code for zenith tv
Try these codes. 0738,0826,0284,0888,0000. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
How do i find the programing code for a universal remote controler for a phillips tv
Try these codes.
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
CODE SEARCH METHOD
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Programing
Hope this helps :)
Programing philip universal remote to my tv
You can find the instructions here. Just follow the step by step instructions to properly select model of your Phillips remote. http://www.urc.philips.com/
21" Panasonic TV W?DVR
Hi : if you're having problem programing the philips remote, you can you used the search option to find the right code for your Panasonic TV. In order to search by auto without a user guide please follow the step below.
1.Turn the panasonic tv on.
2. On the univercial remote control there a button mark code search or search.
Pressand hold down the code search button until the LED light come on steady.
3. Press the TV button onthe univercial remote one time.
4.Press the power button on the univercial remote severail time until the tv turn off
When tv turn off press the OK or ENTER button on the univercial remote control to save the setting.
Good luck.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
