Water dripping from rubber spout on the rubber ring. Starts to pool water in tub.
    Top Expert:
  • Washing Mach... Master
  • 54,195 Answers
Probably a defective fill valve
Posted on Jan 13, 2019
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Posted on Mar 24, 2007
  • 68 Answers
SOURCE: Water runs out out both places for spout and shower head in tub!!
One of two issues. Either the shower valve was installed upside down or there is a twin ell ( Old School Diverter) Partially plugged. Odds are the valve is upside down.
Good Luck, Phil
Posted on Dec 09, 2008
  • 29 Answers
SOURCE: Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Posted on Jan 29, 2009
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Posted on May 23, 2009
  • 226 Answers
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Posted on Jun 14, 2009
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
My graff shower assembly is dripping from the tub spout when the water is off. What are the most common reasons for this? I recently had my water line to my house repaired and wonder if some dirt may have...
maby there is dirt traped behind the showers lock rubber. bt it sounds to me like it is the lock rubber(close) rubber that has parished. replasing the rubber should fix it
Jun 15, 2010 | Graff G-7065-LM15S-P ; G 7065 LM15S P...
There is water leaking from the bottom of the washing machine
couple of things to check, one make sure the drain hose is properly attached and no clogging. and also make sure all gakets are in good shape. and not worn out.
Nov 06, 2009 | Washing Machines
Water is coming from under the washing machine not out of the hoses, where could it come from?
There might be two possible reason for that.
it might be coming form the tub itself passing through the rubber seal of your plastic rotator(the big wheel inside the tub)
the other thing is in the junction of the hose the tub.
try to open the back of your washing macjine where you can get an access inside the wheel and the junction connector, from there you will the cause of the leackage. try to put some water while looking at so you can see where the water is coming out
Nov 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water is leaking out from the bottom
If the washer leaks all the time, check these:
  • Water inlet valve: If water drips even when the washer is off,check the water inlet valve. It is located inside the washer at the back of the unit. The fill hoses are attached to it. Replace if deemed necessary.
  • Water fill hoses: Check the water hoses from the household plumbing. Tighten it or replace it as necessary..
  • Main tub seal: It is located between the transmission and the outer tub. To see the leak, fill the machine with water with small amount of detergent then open up the machine's main access panel.. The leak appears at the underside of the outer tub, at or near the center. The seal is difficult to replace and you probably should call a qualified appliance repair technician.
  • Pump: You can spot the leak when the tub is full of water if the pump leaks. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. Replace it as necessary if it leaks.
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for details.
If the washer leaks only during the fill cycle, check these:
  1. Air-gap device: It is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It is located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. It is usually made of translucent plastic. If one of the air-gap components deforms or cracks, you have to replace it.
  2. The tube: It is a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  3. Inlet spout: It is a plastic spout found on most washers near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Oct 26, 2009 | GE WBSR3140DW Top Load Washer
I'm getting water coming out of the seam on the left side between the top of the washer and the side panel. Is this hard or expensive to repair?
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for deatils.
Oct 24, 2009 | Maytag Washing Machines
When i turn the spout water is dripping out from
There are "o" rings between the spout and the body of the faucet that are getting worn and causing the leak. You need to replace the "o" rings. Shut off the water supply (both hot and cold), remove the handle, and then the spout should slide off exposing the "o" rings. You can get replacements at the hardware store. Put some vaseline on the "o" rings when you reassemble the faucet to keep the "o" rings from curling up and moving out of place. Good Luck.
Oct 22, 2009 | Plumbing
LEAKING FROM BOTTOM
Is it leaking only when it is filling or all the time? If it is only leaking during fill, it could be an air gap device
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • If it is leaking all the time it could be the main tub seal. Hope this helped.
    Jul 16, 2009 | Roper RAS6233KQ Top Load Washer
    Leaking when wash starts
  • Oct 19, 2008 | Maytag MAH2400A Front Load Washer
    Leaking door due to the wire ring that holds rubber seal
    Bosch Nexxt 500 WFMC3301 Front Load Washer how
    to get the metal ring back on.
    This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
    we have all bosch repairs in our channel.
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question.
    Oct 06, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
    Washing Machines Logo
    35 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Marvin
    Marvin
