Question about Samsung Washing Machines
The start/pause button on my Samsung WA13V5 washing machine is not working. The power button is working, however when you press the start button nothing happens.
    Top Expert:
  • Samsung Master
  • 54,195 Answers
Defective button (switch)/control board, or both
Posted on Jan 13, 2019
SOURCE:
  • 156 Answers
SOURCE: Kenmore Elite HE3 washing machine model 110.45862404
ck pump door lock
Posted on Feb 28, 2008
  • 82 Answers
SOURCE: Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Posted on Jun 27, 2009
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
pjhislay1
  • 825 Answers
SOURCE: Hi my Kelvinator kd12 ww1
get onto the supplyer....only a month old.must have some kind of warrenty
cheers
Posted on Mar 24, 2011
  • 6277 Answers
SOURCE: beko wm 5140 washing machine is starting its cycle
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 10, 2011
I have a LG Tromm it starts running in wash mode then a few mins. into cycle it shuts off no codes there is nothing on display
Here's a reset that could work:
To fix this:
  1. Press POWER, and turn the machine OFF.
  2. Unplug the machine.
  3. With the power being disabled, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in.
  5. Power the unit back ON.
  6. Press-in on the door firmly.
  7. Select any cycle, and press START/PAUSE. Good luck
Mar 07, 2018 | LG Washing Machines
My Samsung washing machine is not getting any power
Press power to turn washer off --unplug from wall plug --w/power off press & hold start/pause button 5 sec.--plug in
Feb 02, 2018 | Samsung Washing Machines
The orange on/off button lights up. however the start/pause button does not.
It's hard to tell by the way you've phrased the question whether or not the button is doing what it is supposed to do, or if it is just the light indicator that is not working. So, I will answer both scenarios. // Press start button fully until you hear machine start; (usually less than one full second). In other words, hold button in until ''start'' is _heard_. After start has begun, holding button for 3 full seconds will ''pause'' the cycle. After ''pause'' pressing button again (just like first time) will restart cycle (i.e. ''take it off pause''). But while ''paused'' holding the button in again for any longer than a fraction of a second will cancel the wash. // TO CLARIFY: Press button for approx 1 second to start wash. After start has begun, pressing button for 3 seconds will ''pause'' wash. While ''paused'' pressing button again for less than a second (i.e. ''quick press of button'') will ''resume'' wash. Also, while ''paused'', pressing button for longer than a second (usually 3 seconds) will cancel the wash. // If the machine is (otherwise) working correctly, and your complaint is a light not lighting, then it is just a bad LED light. Best bet is leave it alone. Or, you could buy a new switch if the LED is _inside_ the switch. If the LED is on the control panel, then do yourself and big favor and don't mess with it.
Aug 15, 2015 | Washing Machines
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
How do I use the Child Lock option on Samsung WF-B1456GW?
You can use the child lock feature in 2 ways.
1. To prevent operation of the washing machine when no wash cycle is running
To set this feature, switch the machine on using the POWER button at the top-left of the control-panel. Next, press and hold both the SPIN and RINSE buttons for about 3 seconds - until the child lock light indicator on the control panel illuminates. All functions of the washing machine will now be disabled apart from POWER ON/OFF until such time as the child lock is deactivated.
To deactivate the child lock, press and hold the SPIN and RINSE buttons again until the child lock light indicator on the control panel goes out.
2. To prevent any tiny fingers from tampering with the machine while a program is running.
After pressing the START/PAUSE button to start the wash cycle, press and hold the SPIN and RINSE buttons until the child lock light indicator illuminates. All buttons on the control panel will now be disabled until the child lock has been disabled. When the wash cycle has finished, you will need to switch the child lock off again to reactivate the buttons. Once you have finished using the washer, reactivate the child lock again before switching the power off as above.
The feature can also be used when using the delayed start feature, but needs to be set after pressing the START/PAUSE button.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Feb 09, 2011 | Washing Machines
Washing Machines Logo
159 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
