Wireless to internet use HDMI cable to unit and activate it or pair for bluetooth
SOURCE: LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
SOURCE: att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
SOURCE: Samsung WIS09ABGN LinkStick Wireless LAN Adapter
Do me a favor first, shut everything down and unplug it all the tv the stick and the router and get back to me, thanks, I don't want you to spend money if there is no need,
Gym
SOURCE: Im trying to upgrade my
Don't upgrade the firmware on your Samsung BD-P1600. The firmware from Samsung is faulty and will most likely crashh your machine, Permanently !!!. I made that mistake last night. Now I have no Video output to my T.V. from any of the video outputs on the blu-ray player. Also the unit turns on but will only display LOAD , OPEN, CLOSE, ON, OFF... Nothing Works now.. This is apparently a common issue and there are several forums discussing this problem.. No fix that I have found !!
SOURCE: dvd samsung D7500 region free code
You may be able to get it from one of these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/
www.download-info.com/dvd/index_new.htmDVD and Blu-ray
www.videohelp.com/dvdhacks
