The UR code indicates Unbalanced Load, Retry. That means that the washer continued to spin the drum but at a slower speed. If the error changes to UE or Ub, then the attempt to spin at a slower speed failed.
Unbalanced loads can be caused by the distribution of items in the washer. It can also indicate something between the washer drum and the surrounding tub. Similarly a problem with the bearings or tub supports can cause an imbalance in the system.
I hope this helps.
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
SOURCE: about toshiba washing machine
very simple you just press the WATER FLOW button, PRESET button and RINSE button to reset it memory test it out
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
SOURCE: got error code u11
u11 is not a valid error code - please recheck.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
