Spectre tv constantly scans. (av, tv, media, tv3,tv4,tv8,ect.) What has likely gone bad?
55 inch spectre tv P/n x505vb-fhdu8hj1l01
    Top Expert:
  • Televison & ... Master
  • 76,140 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. {View the site in web view or by a desktop to see the search box. Mobile view has no search box.}/
Posted on Jan 13, 2019
SOURCE:
Benimur
  • 6966 Answers
SOURCE: boise
What model of TV are you hooking the Bose system pls? Alternately, determine if the TV you are hooking it into has a pair of white and red RCA connector marked Audio OUT.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 14, 2008
SOURCE: Hook up
The Bose GS can only support component video set-up for the best video definition. This video connection set-up uses three RCA cables to transfer the video signal from an output device (the Bose GS) to an input device (Your TV).
Check if the back of your GS system has a set of video out RCA ports that are titled "Comp Out". You TV should then have a "Comp In" video input RCA ports you can connect to.
Hope this helps.
Posted on Oct 21, 2008
  • 92 Answers
SOURCE: 2002 Kia spectre Odo meter
check over tranny,you will probaly find a elec connector that is not pluged in.
Posted on Nov 07, 2008
SOURCE: log on problems on tagged
why the tagged always loading?? can't log in
Posted on Nov 28, 2009
  • 369 Answers
SOURCE: I am unable to get my 2001 spectre into gear. I
If it has a center console inside the center console is a shift interlock solenoid which when the brake pedal is depressed sends a voltage signal to the shift interlock solenoid which then unlocks the shifter allowing you to shift it. It may be bad look into it. You can also manually unlock the shifter by pulling the small plug on the console next to the shifter then sticking a screwdriver down in there far enough to un lock the shifter they made that for this reason.
Posted on Dec 01, 2009
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Ekse
