Question about Frigidaire Washing Machines
Frigidaire laundry unit makes squeaking noise at times during dry cycle. Might need to replace bearing. How?
SOURCE: Squeaking!!!!
Asko T701 dryer,
Squeaking loudly for the full dry cycle
Warrant wet out last year. We complained to the repair man that it was squeaking prior to the warrant running out, he said they just do that. It is now very loud and I know noise = friction, and I am concerned. I looked into it and sprayed some silicon on the belt, but it sounds like the front gasket is the problem.
Is this a common problem, and is there a common fix?
John
Posted on Jan 21, 2008
  • 1028 Answers
SOURCE: Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Posted on Apr 19, 2008
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Maytag neptune dryer has a very loud squeaking
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Jan 01, 2010
  • 27 Answers
SOURCE: The washing machine started making a grinding
sounds like a bearing... although it could be the water pump... water pump is an easy fix... bearing is not an easy fix... take the belt off the bottom of the pump (under the machine) and see if it spins freely by turning it w/ your hand... or if it seems really stiff... if it looks good then it's def. your bearing...
Posted on Jan 15, 2010
Washer squeaks during agitation, both wash and rinse. also makes thumping sound for few seconds after spin cycle stops.
Hello Chris, thank you for your post!
I see that the washer on your Frigidaire laundry center is squealing during agitation. This noise could be coming from the motor or transmission and you may need to have the washer disassembled to locate which component may be causing the issue. For proper disassembly you may need to seek assistance from a professional technician. A technician will have the appropriate tools needed for complete disassembly of the washer without causing personal injury or harm to the laundry center. Hopefully this information is helpful towards your repair. -Matt
Apr 20, 2016 | Frigidaire fex831cs stacked washer&dryer...
Why washing machine squeaks when in wash cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a squeaking noise during the wash rinse cycle on your Frigidaire washer. You could be hearing the noise from your motor during that operation, this is normal. Additionally, if you feel that this is noise an issue I would contact a professional to come out and diagnose your appliance properly. -Matt
Aug 23, 2014 | Frigidaire Washing Machines
My Frigidaire Gallery dryer squeaks and leaves brown crescent burn marks on our laundry items.
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
Dryer repair Pasadena CA Bosch LG Electronics Amana Beko
Sep 02, 2017 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE Gas Dryer DBSR453GB1WW began squeaking during the most recent drying cycle. We should we try to repair ourselves or get a repair tech?
The squeaking noise is most likely emitting from the drum bearing (key#543). In order to access and replace the drum bearing will require removing the drum. The drum bearing/sleeve is part# WE1M462. I added the instructions on how to remove the drum in the images below. NOTE: Disconnect the power cord from the power source before servicing the dryer.
Jan 13, 2011 | GE DBSR453GBWW Gas Dryer
Whenever we are drying a load of laundry the dryer has started making a banging noise as it rotates
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | Frigidaire Dryers
Dryer is making a high pitch squeak, sounds like a rusty swing. possible bearings
You probably have dry bearings from all the heat over the years. Unplug the unit and remove the back to expose the bearing and shaft. Using a light oil such as 3-in-1 squirt oil into the bearing and let it soak in. Do this several times and keep a rag under the bearing to catch any excess oil. Odds are that with a little lubricant the dryer will quiet down and work fine for many more years. This would also be a good time to clean any lint and dust bunnies out of the unit. Reassemble and test. You should be good to go. Let me know if I can be of anymore help.
hardrocko
Thanks for using FixYa
Feb 20, 2010 | Frigidaire FEX831C Stack Electric Laundry...
Washer leaks during spin cycle
If the machine is leaking then the bolt on the drum need to be tightened. you can acces them by removing the top or rear cover of the machine. If the machine is wobbling it need to be leveled or a shock absorber or spring connected to the drum has come loose or needs to be replaced
May 31, 2009 | Frigidaire FEX831CS Top Load Stacked...
Irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
Washing Machines Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
