SOURCE: when i try to turn
It sounds like you may have either a defective video card or RAM. To test the RAM, open up the RAM bay on the bottom of the laptop and remove one stick. If the computer still isn't starting, swap the stick that you took out with the one that is still inside. if that didn't help then you should take it in to the manufacturer for repairs. NOTE ABOUT HANDLING RAM: RAM is very sensitive to static electricity so be very careful not to touch the gold leads on the bottom. Good luck!
SOURCE: I have a Hayward HD100ID
Since this heater was only purchased last year, if it is faulty they should cover it under warrantee. If you call Hayward technical support they should be able to help you figure out what the next step is. I hope this helps.
I had the same problem. The lid lock assembly is broken.
If you are under warranty get it replaced. If not remove the top of the washer
and take out the switch assembly. The 4 wires going in are Yellow, Red, White,
and Blue. If you short the white and blue together, the washer thinks the lid
is closed. If you short the red white and blue together the washer thinks the
lid is closed and locked. The yellow is only there to activate the
electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter
of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if
you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Hi John Flanagan, Which brand is the drone and what is supposed to happen? If you don't know, can you tell me where you bought it or make a picture of the drone and the package?
