A few years ago, I deleted my drawings on DrawCast to refresh my account, but now k deeply regret it. Since then I've switched devices so it's not stored in my previous projects. I've tried looking in other people's liked drawings but once it reaches a certain point down the page, it glitches out and kicks me out of the app. I've tried many times. Is there any way to get those drawings back? Thank you.
SOURCE: Start-up of i-mate JAMA
I was having the problme of startup screen was stucking at Green screen. I have contacted thge live support, they told me to Hard Reset the device.
For Hard Reset
1. Remove the Battery
2. Press and hold the Call End key and Volume Decrese button for a while.
SOURCE: I Mate Jama Start up problem
make a hard reset to your I-mate jama
Remove the battery, Simultaneously hold volume(-) button and red hangup
button, while still holding those keys, insert the battery and wait for
the led to go out, release keys and device will hard reset.
Start->Settings->System tab->Master Clear->1234->ok
here is the video for how to
http://mygsmtube.com/videos/198-imate-jama-hard-reset-howto.html
SOURCE: kettle shuts off before boiling?
I had a similar failure. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettlefuls; so far so good!
What ticks me off about this is that I don't mind getting 'Made In China' ****; everything comes from China anyway. But don't charge me a ridiculous amount of money and try to pretend that I am getting a superiour product. If I had paid twenty dollars or less for it I would just chuck it and get the same one again because it looks nice, pours well, doesn't burn the hands, worked OK for couple of years, etc. Instead I walk away from this feeling really ripped off. I have a house full of Braun products(shaver, kettle multiple tooth brushes) but now I won't buy any more.
Oh and if you take your kettle apart and your house burns down it is not my fault. There, now I feel better.
SOURCE: engine died.won't start.
Sounds like your crank sensor is faulty.These engines are known for crank sensor and ingition control module problems
SOURCE: Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove
the key and UNPLUG THE POWER CORD.
Using the hex key, turn both rear roller bolts clockwise,
1/4 of a turn. When the walking belt is correctly
tightened, you should be able to lift each edge of the
walking belt 2 to 3 inches above the walking platform.
Be careful to keep the walking belt centered. Then,
plug in the power cord, insert the key, and carefully
walk on the treadmill for a few minutes. Repeat until
the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
This is awesome to get this by using this tool.
