Cycling Logo
Butch Roos Posted on Jan 12, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Type of 12v in helix huffy 18887A
Want to know what 12v battery in huffy helix 18887A to replace
Suzanne drewett
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 03, 2022
Suzanne drewett
Contributor
Level 1:
Answers
Questions
0
Helped
415
Points
When I press excalrator there no sound nothing please help
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Jan 12, 2019
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1814407
Points
14613
Take old battery off first it will tell you on there, as long as it 12volts and the same size then it will do the job.
Parts for Huffy Maxx? I need a left side crank and nut.
Question moved from Computers to maker category.
Order Replacement Parts
Huffy Bikes https://www.huffybikes.com > parts
We make it easy. Here you can order free warranty parts, or purchase the replacement parts you need. *Note: Battery products including ride-on toys, ...
Missing: Maxx ‎' Show results with: Maxx
Order Replacement Parts-Bikes, Scooter, Ride On Toys
Huffy Bikes https://www.huffybikes.com > index > findproduct
Order replacement parts for your bikes, scooters, and battery ride on toys. ... and FAQs about warranties, warranty parts, returns and order cancellations.
Huffy Vintage Bike Parts for sale
eBay https://www.ebay.com > ... > Vintage Bicycle Parts
Get the best deals on Huffy Vintage Bike Parts when you shop the largest online selection at eBay.com. Free shipping on many items ' Browse your favorite ...
Bike Parts and Accessories
Huffy Bikes https://www.huffybikes.com > parts-accessories
Results 1 - 8 of 8 - Bicycle parts, smartphone holders, repair kits, and officially-licensed accessories from Disney and Marvel allow you to get the most out ...
What type of 12v battery used in huffy helic electric scooter
I think you best to take the batter out and look on Ebay for one most are just a small 12 volts battery.Clive
2helpful
How do I replace my Helix eraser
With a small needle nose plier or tweezer pull the metal eraser holder out and put a new eraser in then stick it back into the body.
Thats it!
I dont know what it means when i am flying my helix and the power light on the control starts blinking? can somebody help me?
Weak batteries in the transmitter, or you're losing communication with the helicopters receiver. Check the IR receiver under the heli. it may be pushed in or to one side. ~VLAD~
2helpful
2answers
Need replacement balls for a Huffy electronic
I have found the number for Huffy. You should be able to see if they have replacement balls for your electronic basketball game.
U.S. Customer Service
Email: [email protected]
Phone: 1-262-820-3440
Phone: 1-800-558-5234
Fax: 1-262-820-6757
Thank you, hope this helps. Please let me know.
2answers
Battery
It need to replace 2 piece of regular 12V.7A SLA battery. It is easy to buy in the market.
New starter does not work
The spring on the starter motor helix is either stuck or broke, or the starter gear is jammed in the flywheel gear.
Take the cover off the starter motor and you can see the flywheel, starter gear, spring and helix shaft.
If its just stuck, free it up and spray some WD40 in there.
If the gear was jammed into the flywheel teeth then check for damage and wear. They are made from quite a soft metal and burrs can easily be filed and removed.
The "clunk" you are hearing is probably the starter solinoid. If you think its a more mechanical sound than that, it could be the starter taking up slack against a jammed gear.
If the engine runs file on a pull start, its unlikely to be a jammed gear/flywheel and more likely the spring is broke or the gear is stuck at the base of the helix.
If its none of those things and the clunk is the solinoid, then you will have to check to see if 12v is getting to the starter motor. If so, it might actually be the motor.
So, in order of likelyhood/checking:
1) spring stuck or broke
2) Gear jammed on helix
3) solonoid <-> motor electrics
4) gear jammed on flywheel
Its a good idea to keep in working - very sensible.
Top Huffy Cycling Experts
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
