SOURCE: Since the switch to digital transmission, my
to add to what MIKEY-MOORE wrote, OUR government was offering discount ($20 off a $40-$45) coupons on a digital converter box that you can use your original antenna ( I still use my original nineteen and 65 (1965) rabbit ears antenna) to receive the digital signals NOW being transmitted through the air. In order to receive the signals YOU MUST get the converter. GOTO any Radio Shack, Walmart, to acquire the converter box. You will need one for EVERY tv in your house. I have a HDTV (but not digital) and I had to buy 3 boxes.
SOURCE: how do I hook up my tv to regular reception using
you will need to buy a digital converter box to get regular tv. The fcc has changes the way you get tv over the air. check at radio shack and they can get the box for you. should be around $40.00.
If the antenna is working and you are not receiving a signal, then you could have a bad tuner, use a tuner from a VCR , connect the ant to the VCR and go from the VCR with Video cables and go to the Video input on the TV and put your TV in Video mode. That will work.
