When pressing buttons it does not respond
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
SOURCE: Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
