Televison & Video Logo
D
Dan Mcguire Posted on Jan 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung 65 5yrs. It has a black screen with white strobe flashing. It has audio. Now what? Thanks
Model: un65eh6000f
City View TV & Computer, Inc.
Level 3:
Master:
  • Samsung Master 453 Answers
  • Posted on Feb 08, 2019
Samsung Master
Level 3:
Master:
Answers
453
Questions
Helped
147851
Points
1036
In most of the case, the back lights LED strip is bad.
4 Related Answers
Anonymous
  • 563 Answers
  • Posted on Apr 18, 2008
SOURCE: Sanyo high definition tv
Hi there
Could you please supply me with the Model of this Sanyo TV ?
PNiss
  • 151 Answers
  • Posted on Jul 13, 2010
SOURCE: Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Anonymous
  • 17 Answers
  • Posted on Jul 23, 2010
SOURCE: flashing/strobing picture
have you replaced the lamp?
Anonymous
  • 811 Answers
  • Posted on Jan 13, 2011
SOURCE: Monitor flashes black and white rapidly like a
The easiest way to check this problem out is take your monitor over to someone who has a computer or if you have an extra computer at home hook the monitor up to see if it stops doing this. Then you will know if it is not the monitor. Then you can focus on the video card going bad or is bad. Change the card with a new one, problem is solved. Check the cables connections make sure they are not loose as well. Restart you computer also discharge it by pushing in the power button in while the computer is unplugged from the wall. John
I have a Toshiba PDP50X3 TV. When I push power button the screen keeps flashing white like a strobe light but it won't power on.
LEDs in the panel are bad. It is almost impossible to repair this. If under warranty, the panel would be replaced. Shop for another TV. Thanks for asking, Matt of Martins TV Repair.
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
2answers
Remove light governor
I installed my Hunter Ceiling Fan a little over a year ago. A few nights ago my wife told me the lights in the ceiling fan blinked a few times when she turned it on. Over the next few day the problem got much worse. When I turned on the light switch, the lights would not turn on. After a few minutes the lights would begin to flash, like a strobe light. This flashing would last for about a minute.
This morning I removed the light kit. I noticed the watt regulator, part 98480-02. I connected the wires directly that were wired through the regulator. So far, the light now works fine!
Vizio screen flashing
ok when mine did that i shut it off then on then off then on again four times then unpluged it and plugged it back in and waited for a few minutes and it was fine if that don't work then its most likely an internal problem and it would have to be fixed by a professional
Samsung tv model LNS3241DX flickers
I'm not sure of a jumper wire to cut, but one of the first things is to clean out the dust that has accumulated on the electronics. You can blow out the back with compressed air or disassemble the TV case and dust it. Sometimes a layer of dust can cause excessive heat to build and shut off any type of overload circuit. Good luck!
Flashing vizio plasma tv
Open it up and locate the source of the clicking. Chances are that is the defective board in your set.
TV Parts Universal TV Stands DLP Chips ShopJimmy
1helpful
Thers 4 wires to connect 1 red 1 black 1 white and
Well, if there are no color lights on this strobe effect, a fairly standard color code for AC is Black is HOT White is Neutral, no insulation is ground and Red would power your strobe ( I Think )., I would hate to misinform you. Is this an AC powered strobe? Like when you wire up a ceiling fan you have the same color code. I'm sorry I can't help you further, and messing with live AC can be unsettling.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
