The feed dog position switch is on the back of the Singer Ingenuity 7436, more or less even with the needle bar mechanism. To raise the feed dogs, make sure that the presser foot is up and the needle is at the highest point. Remove the accessory box by pulling it to the left of the machine. Turn the sewing machine around so that you can see the feed dog control lever. Push the lever down (towards the sewing table) and then move it to the right (away from the motor/control section of the machine). Turn the sewing machine around (to the normal sewing orientation) and turn the hand wheel counter-clockwise (towards you), until you hear or see the feed dogs click into the correct position. Note: make sure that the bobbin winder shaft is to the left (not the far-left or right positions). If this doesn't work, then there is probably a broken part in the feed dog or its lift mechanism. The machine needs to be repaired.
The directions to raise the feed dogs are shown in the manual on page 12. The current link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%207436%20INGENUITY%E2%84%A2%20Sewing%20Machine.pdf . Many Singer manuals are available from the support page: https://www.singer.com/support . You don't need to enter the full model number to find the manuals. Include any leading letters and some of the numbers in the model number. Leave off any letters at the end of the model number.
I hope this helps.
SOURCE: raising bobbin thread
These machines are timed by belt and go out of time a lot. Check and see that when the needle passes through the plate and travels upward 1/8" at this point the rotating hook should be right behind and above the eye in the needle,my guess is that it is out probably 1 tooth on the timing belt and can usually be corrected by removing the bobbin case and holding the rotating hookk with on ehand and forcing the handwheel with the other hand which will cause the belt to jump a cog and should put your machine back in time I hope this helps
SOURCE: My Singer 7436 keeps getting an error code 88
I have been having the same thing happen. I just discovered the bobbin winder was in the wind position. I moved it and I am in business again! Hope it works for you!
SOURCE: I have a Singer Ingenuity Model 7436. It won't
Any computerized machine needs specialist attention from the dealer who has the testing equipment
SOURCE: Need a new power cord for Singer Ingenuity 7436 sewing machine.
Direct from Singer or main agent
