SOURCE: Thermometer
YOu have to be more clear on the post it dont make much since, also if its brand new should be under warranty
SOURCE: we have a liebherr 7082
The two flahing lights are normal if the freezer is warm. It will display temperature when it gets cold. If it doesn't get cold there is another problem.
SOURCE: got an american whirlpool fridge
may be a indication only but on many fridge-freezers, 2 flashing lines ,means power interuption
SOURCE: Fan not working, temperature too cold
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
