Agitator spins but tub only rotates slowly.
SOURCE: Hoover washing machine not spinning
Possible your outlet filter is blocked, check this out first, then your outlet pump, and clean it; refer to your manual.
SOURCE: Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
SOURCE: 110.82980 top load washer (kenmore) agitates when
The shift actuator in the gearcase is bad.
Replace the transmission.
