SOURCE: RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE
Answer for how to program the RCA RCR3273 3-DEVICE SNOWBOARD UNIVERSAL REMOTE:
Make sure the device is on. Hold down the tv (or whichever device you're trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly, letting it flash until the device turns off. Then press the stop button...and it is programmed.
[email protected]
http://www.angelfire.com/journal/archer/index.html
SOURCE: Remote control programming codes
i have a GE t.v. and just bought the RCA DTA800 converter box. none of the codes that were in the manual worked for my t.v. can anyone help?
SOURCE: RCA Universal Remotes and Digital Converter Boxes
A converter box will not work you need another advanced remote for that try www.remots.com and see if they can match you up with a solution. Thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
