SOURCE: Thermador Cook 'n' Vent Stove with stuck vent (model # SGCS304RS)
I just had a similar problem. The switch knob, and backer for the blower got jambed in the housing. After pulling it all apart I called the parts center at Thermador and ordered a new switch. If you can hear the motor the raises the unit run, then that could be your problem.
SOURCE: My 7 1/2 year old Thermador CVS36RB Cook 'n' Vent won't retract
sears labor is 137 plus parts. that is something that would need to be looked at. it could be a few different things. if he is handy he can open it up to see if anything is misaligned or broken. the vent may even just be a little crooked and once straight may go up and down like normal
SOURCE: Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
SOURCE: Thermador cook n vent stuck in the up position. We
replace the switch if the switch is going on and up position and not in down position the you should replace the switch for this part you can order it from thermador if they still stock the piece hope this helps
SOURCE: Model SGCV36G Thermador Cook N
Hello. Chances are that the mechanism just needs to be cleaned and lubricated. Unscrew the panel to gain access to it and take a look see. Clean it with any degreaser and then lubricate it with some white lithium grease. Joe
Thanks for choosing Fixya!
