Hi
Please see the suggestions below which hopefully get the camera working again
1. Have you tried a fresh set of alkaline AA batteries? If so have you tested these batteries in another device so you know they are good?
2. Have you checked the battery compartment terminals and battery bay door terminals are free from corrosion?
3. Check all the buttons on the camera to ensure they are moving freely. If some dirt gets jammed into one of them it can make the camera think the button is being pressed and it will not allow the camera to switch on.
I hope one of these suggestions helps to get the camera up and running again.
SOURCE: Kodak easyshare C182 camera. It is six days old
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
Contact KODAK:
SOURCE: I need a manual for the Kodak easyshare C182
You can find the manual from this address.
http://www.kodak.com/global/en/service/publications/urg01042toc.jhtml?pq-path=15490
SOURCE: Kodak Easy share C182 Digital Camera
Please check that you have putted kodak alkaline batteries.
SOURCE: How do I upload pictures from my Kodak c182 camera
Use the cable that came with the camera to connect to your computer via a USB port.
No cable?
Use a card reader, these are cheap about 7-15, and carefully insert the card from the camera into the reader and connect to your computer.
SOURCE: lens error 111 camera is Kodak
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
