SOURCE: bottom not cold enough
did you remove the back freezer panel ? if not need to
is there a large anmount of frost on the coil behind the panel?
if there is thaw the coil with a hair dryer
if there is no frost on the coil you have a sealed system problem that will nee to be taken care of by a tech
if frost is on the coil you have a defrost heater defrost thermastat or defrost timer that is bad
SOURCE: Ice maker is freezing up
The solenoid valve can leak slightly to make your problem. To check it, undo the tube from the solenoid to the freezer with the solenoid unplugged, and the water pressure on. Any leakage is bad, replace it.
SOURCE: ice forming and freezing in the freezer bottom
Need to find out if the refrigerator is going into defrost normally, about every 8 to 10 hours. If it does defrost normally, does the drain inside the freezer panel and under the evaporator coil drain without blockage? Defrosted ice, (water) should go down a drain pipe and into a pan near compressor. Let me know, Thanks, Sea Breeze
SOURCE: GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
SOURCE: WATER FREEZING IN ICE MAKER
check 2 things. Make sure the fill tube is going downwards to the cup inside. The second thing is when the valve shuts off make sure it closes right away. If it doesnt then replace the valve.
