Model number is wtw7340xw0.....looking for capacity to compare with replacement
SOURCE: WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
SOURCE: Kenmore washer Series 90- #110.20924990
Sounds like my problem I just had...motor coupler needed replacing. I fit between motor and transmission and if it is broke motor will turn but agitator will not work as coupler is not turning
SOURCE: What is my washer's capacity?
able to find a spec sheet on your specific washer, but i can tell you that you have a whirlpool made kenmore washer. and at 18 yrs ago they have only gotten larger, youd be hard pressed (unles you bought a apt sized machine or a laundry center) to get a smaller capacity machine. new machines are huge in comparison to the oldies
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
SOURCE: WHAT IS THE SIZE OF MY WHIRLPOOL WASHER?
We have the same model. We plan to purchase a replacement washer, and tank size is a major factor.
Machine manuals are available at www.whirlpool.com. It's great Whirlpool has the docs available online, but there was no indication of tank volume for this model found in the manuals: Parts, User, Instructions.
I decided to figure it out by filling the washing machine tank manually counting the number gallons of water dumped in. I managed to dump in 23 gallons before risking overflow. I don't recommend this approach since the specified water level limit for the tank assembly may be lower than the perceived water level limit. This volume test was performed on a machine that's being disposed.
Google says 1 US gallon is equivalent to approximately 0.1337 cubic feet. Applying this ratio to the number of gallons poured in, the volume is 3.08 cubic feet. If 24 gallons, then 3.21 cubic feet.
I'm sure the tank is not 4.0 cubic feet since that would have required another 7 gallons of water, beyond the 23 already poured in, making a mess on the floor, and potentially wetting machine wiring and other hardware that should remain dry. Even if we account for the space occupied by the agitator, it's unlikely an additional 7 gallons of water could be added without significant overflow.
4.0 cubic feet is approximately 30 gallons.
We're going on the assumption our LXR9245EQ2 washer is a 3.2 CF machine.
