Hi Try this website it may be a help click on link it will take you there and has a shot video ,
https://www.youtube.com/watch?v=iq8Wi5PsY6U
and 2 https://www.youtube.com/watch?v=Z1-QB9xK4yM
and 3 https://www.youtube.com/watch?v=ZZYLnbkfSWk
Good Luck. Clive from Holyhead
SOURCE: Royal Cash Register 130 cx Does Not Print Correctly
Cleaning and alignment is needed to solve these problems. As you can notice, the printer has various gears and small parts on it. Although the alignment for this kind of printer model is too complicated that only an authorized technician is capable of doing it. If you can look for an authorized service center for your cash register on your area then try to contact them. They either render home service or you will have to bring your unit to them.
SOURCE: Sharp cash register XE-A41s
Hi. turn key to OPX/Z mode. Press the receipt button. Turn back to REG mode. Now when you want to issue a receipt, press the receipt button.
Mark
SOURCE: Sharp electronic cash register XE-A203 - keeps printing receipt
I don't have this particular cash register, But I took a look at the manual and I recommend the following:
A. Turn the cash register off.
B. Unplug it.
C. Remove the batteries.
D. Wait at least five minutes.
E. Initialize the cash register. This procedure was copied from thwe manual:
In order to operate the cash register properly, you must initialize it before operating for the first time. Follow this
procedure.
1. Insert the manager (MA) key into the mode switch and turn it to the REG position.
2. Insert the plug of the AC power cord into the AC outlet. The buzzer will sound
three times.
IMPORTANT: This operation must be performed without batteries installed.
3. The cash register has now been initialized. The register display will show
"0.00" and then “NO BATTERY”.
If the buzzer does not sound when the plug is inserted, the initialization has not been done
successfully. (This will occur when the voltage is high because you operated the cash register
before starting initialization.) Wait at least one minute after pulling out the plug and insert the plug
again.
F. Download trhe manual from here:
http://www.ormsson.is/skjol//skrifstofutaeki/xe-a203,213,303_manual.pdf
And proceed to program your sales tax (or VAT), departments, clerks, etc.
SOURCE: our cash register gives a E001 and he wont start
Hi. If it is a Casio, then you have turned the key before you finished. turn back to where you were before, and finish what you were doing in that mode
SOURCE: How to turn off cash register journal printing (casio CR140)?
If it's not in your manual you can't turn it off. Besides why would you want to turn it off. It's there to make it easier to find mistakes and to make it easier for you to catch your employees stealing from you. Leave it on; paper's cheap.
