Step 1
Open the rice cooker by unclipping the locks which are on the edge of the lid. Remove the lid and pan insert.
Step 2
Place the rice and water into the pan.
Step 3
Replace the pan insert, ensuring that the ridged edges and handles are facing upwards.
Step 4
Close the lid and lock it into position by securing the lid clips.
Step 5
Place the rice cooker into a microwave and cook, on high power, for approximately seven minutes.
Step 6
Remove from the oven and allow the rice to stand for a further five minutes.
Step 7
Remove the lid and insert. Gently stir the rice and serve it immediately.
SOURCE: Rice cooker stopped working
Sounds like the Thermal Fuse inside is blown unscrew the 2 screws on bottom of the cooker you should see a small 2.5 inch insulation wrapped wire leaving a ceramic mounting block to one of the element poles. Now you take off the nut and unscrew it from the pole. Cut off the insulation and underneath will be a Thermal Fuse. If you have a Ohm Meter or a continuity tester attach each lead to either side and it probably will test negative. Part # is written on the Thermal Fuse. Probably a
SEFUSE
SF188E
192C
10A
250V
They are for sale on ebay for $9.99
I'm trying to get mine cheaper elsewhere
SOURCE: Need instructions for National Rice-O-Mat Rice Cooker SR 10GHN
You can just go to a web site and look search for Rice Cooker Steamer. And find some important information.
SOURCE: Wolfgang Puck 7 cup rice cooker instruction manual missing
Here the standard manual : WOLFGANG
However you can read and print recipes online from their website , click below:
Rice Cooker Recipes Cookbook : Recipezaar
Rice Cooker Creations Cookbook
SOURCE: Rice Cooker Instructions
For Queenmom and anyone else looking for the manual for a Black and Decker Flavor Scenter Handy Steamer Users Manual, I just stumbled across one. Here's the link:
http://useandcaremanuals.com/pdf/HS90038.pdf
I hope that helps.
SOURCE: directions for tupperware rice cooker
The rule of thumb is too put roughly twice the amount of water compared to the rice. Then press cook and it will shut off and go into "warm" mode on its own. If you want to steam something just put a little water maybe a few cups and put you vegetable etc on the grill that came along with it and put the cover on.
