You can attach some flash drives to Apple's $29 iPad Camera Connection Kit. (If you have an iPad with a Lightning connector you'll additionally need Apple's $29 Lightning to USB Camera Adapter.) Let me underscore some. Some flash drives require more power than the iPad can provide and won't work.
For the second question, here's also a guide to help you back up iPad music to iCloud.
Connect your iPad to a Wi-Fi network.
In iOS 8 or later, tap Settings > iCloud > Backup. ...
Make sure that iCloud Backup is turned on.
Tap Back Up Now. ...
Make sure the backup finished by tapping Settings > iCloud > Storage > Manage Storage, and then select your iPad.
if a lightning strike was anyplace close (30 yds) it's a safe bet your gonna have to replace the control board in generator also Id have a qualifyed tech ck out your auto transfer switch ,I bet he''ll find that you fried your coils on your switch too , do that before changing control board cus if ya hook up a new one to a bad coil ya just bought two of them
If u have USB cable that came with the phone it should be easy. just plug it in and after few seconds new options should appear. then just open folder inside your phone(on PC) and search for your photos
You might have had a power surge.Try unplugging your TV for 5 minutes and plugging it back in. If you cannot get a picture from any device such as a DVD player and cable then your TV needs serviced call a repair man. Good Luck!
Same problem here with the ASCO 165, after a couple of fierce lightning strikes yesterday that did over $10k damage to my neighbor's electronics, and also took out my garage door opener.
I'm pretty confident the control board is the problem, but I don't plan to try to replace components. Will probably opt for a new control board from ASCO, or another source, assuming they are still available.
Try this which should reset your ipod: First, toggle your hold switch back and forward and put it back to the off position. Then press and hold the menu button and the center button simultaneously for about six seconds and the screen should go blank and the apple logo should appear. After that it should work.
when you connect your camera to the PC.
look in My computer and find the drive ( camera ) probably shows as Drive F:/ G:/ H:/ I:/ or similar.
Right click and open, then copy to folder on desktop, named My-Pictures ( Or similar ) once you,ve copied your photos from memory card to desktop on PC. Format the memory-card. which will erase all data. ( Right Click Format )
