SOURCE: Maytag Skybox
Whats your email I will send it to you Also you can go to www.apdepot.com to get a parts breakdown
SOURCE: Maytag Skybox Beverage Dispenser Not Cooling
Sears.com is selling skybox parts. Go to appliance and parts and put in the model number of the skybox it is either mbv1976aab or mbv1976aap -- you can find this on the back of the skybox. It might have the part you need.
SOURCE: maytag skybox not cooling need name of place and
before replacing parts. unplug it and from back and under neath get all the dust out,best to blow air in there to remove dust than plug it back in and leave it on number 3 setting for 6 to 8 hours than if cold you can adjust the settings.
or part location is at www.maytage.com/skybox parts
Good Luck Im pretty sure you won't need to buy part's after air cleaning
Testimonial: "`will try it and let you know.....thank you very much,,,,,,"
SOURCE: MY MAYTAG SKYBOX WILL NOT COOL, MBV1976AAB
If the compressor is running then this has a sealed system issue and that is not repairable in many cases.
SOURCE: Maytag Skybox MBV1976AAB Compressor Start Relay
Hi, Relay switches can be found easily on amazon, take a look here: Check out TRENDnet latest products. Wish you best of luck.
John
