SOURCE: unlocking my radio, 2005 pathfinder
As far as I know there is no code on a Nissan factory radio. Check the fuses for the radio.
SOURCE: Lock code for radio cassette
I have a 98 BMW I bought and the battery went dead. How do I enter the code to bring the radio on. I need some who can tell me step by step. When I code button the code button flashes Code_ _ _ _. What do I need to do to enter the code.
SOURCE: Hi, problem with 2007 VW Citi Golf radio security code.
The radio is in Lock-Out mode. You only get two attempts to enter the code, then it enters Lock-Out mode.
Put the key in ignition and turn on the radio for an hour (maybe a bit more). The radio should reset itself after about an hour and then you can re enter the code.
SOURCE: 2001 Audi A4 radio in safe mode. Battery was
sorry to say, you will need to take it in, it needs to be hooked up to their computer to reset and have it start up poperly. It just like a pc when it crash it will try to start in safe mode until you select "Normal" start up
SOURCE: hi i have a 99 range rover p38 the key fob is
The BECM will retain the EKA code, so , charge or replace the battery. Close all doors, windows bonnet etc, then try the EKA code. You must know, that if you enter the incorrect code or do not enter the code correctly by returning the key to the centre position after each turn of the key , more than 3 times, then the system will lock out and you will have to wait 30 minutes to retry. It should start , but it would be good to get another remote handset, Hope that helps
Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
Enter your code to open the safe.
Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
Use your code to open the electronic digital safe's door.
Locate and remove the battery cover on the inside of the door.
Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
