Hello, M Ali -
If you have not yet done so, I suggest you contact Safety1st Customer Care directly and ask if instructions are available for your buggy, which is no longer manufactured. This is the link to the Safety1st Contact Us web page:
https://safety1st.zendesk.com/hc/en-us/articles/205584369-Contact-Us
Best wishes.
SOURCE: i cant fold my maclaren twin buggy!
I will try to explain this best I can without actually having it in front of me. First off, start on one side or the other, doesnt matter which, take the top of your foot and pull up on the metal supports on the bottom of the back side of teh seat. You want to pull up in the center, under where the plastic "step" looking piece is. repeat this on the other side. Then you will push down on the littel lever that sticks out of the right side of the buggy. This releases the lock. Usually, you will then have to pull up again with your foot in the same place as before and push the handles of the stroller forward. The buggy should collapse. You may try some 3-in-1 oil, silicone spray or Pledge furniture pilish on the lever and "joints" to make it fold a little more smoothly.
SOURCE: my buggy is a quinny zapp i dont know how to fold
First make sure the brake is on. There are two round Grey buttons, one on either side of the frame (about halfway down) they should have a small red triangular numbered sticker above them (1 & 2) Stand behind the pushchair where the handles are and press the left one in (that's number 1) and gently fold the frame a bit but not too much! Do the same with the right one (number 2) when the frame starts to fold in bend the bar down that sits between the handles and place your foot on the Grey pedal located at the bottom of the frame in between the brakes (number 3) and slide it towards the front of the pushchair, as you do this the whole frame should close up.
SOURCE: help to fold down buggy
Hi, apply the brake.
Go round to front of buggy.
Hold the 2 large grey buttons on side of frame.
1 pushes down 1 pushes forwards do this & pull buggy down towards you, this will fold it as long as the brake is on.
SOURCE: handle has two release catches,for folding buggy
www.fixya.com/support/r7805199-fix_bugaboo_handle_lock
