SOURCE: Battery charges but is dead
The battery isn't any good. The charger is just going through it's regular steps. (I know how it is. I just bought two Ryobi 18 volt batteries for my Ryobi cordless drill, reciprocating saw, flashlight,
trim circular saw, combo set. $60 for two batteries)
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen.
Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
SOURCE: why my 28v doesn't fully charge
One or more cells of the battery have gone bad. The technique of measuring the state of charge of the battery is VERY limited.
I would recommend letting the battery cool after charging... THEN in a day, charge it again without using it. Do this for several days and see if the battery improves. If not, time for new battery.
DO NOT discharge these batteries beyond the point where the tool starts to slow down. You will reverse charge the weakest cell from the ones still deliveing power and the reverse charge will permanently damage the weakest cell.
SOURCE: Battery not charging ?
Advise you to buy a new Digital
Camera Batteries for Canon PowerShot SD1100 IS
Replacement for: CANON NB-4L
,cheap and good performance.
SOURCE: 2004 honda cbr rr1000 want
The battery and stator.Both needs to be checked and replaced.The stator charges the battery when bike is running.If the battery is old, as per me battery life is approx 2 to 3 years.In your case battery not holding charge. Replace the battery, this should take care of problem.But if problem is same then stator also has to be replaced.-------- This will help.Thanks.Helpmech.
