Question about HP Office Equipment & Supplies
Error 0xd05d010d reinicio de alimentaci?n en HP OfficeJet 5610 todo en uno. ¿Qu? puedo hacer?
rakeshpramod
  • 234 Answers
SOURCE: Error code 0xd05d010d reset power
Unplug the power cord from the All-In-One as well as the power outlet.
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
Posted on Sep 17, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Desconectar
Decime el modelo de tu televisor tiene que ser un numero como este
Sylvania SST4324S 32"
Sylvania SST4324A 32"
Sylvania SST4324 32"
Sylvania SST4323 32"
Sylvania SST4322 32"
Sylvania SRT2432S 32"
Sylvania SRT2432P 32"
Sylvania SRT2323 23"
Sylvania SRT2232X 32"
Sylvania SRT2232S 32"
Sylvania RSET432E 32"
Sylvania RSDCT3203 32"
Sylvania LD320SS8 32"
Sylvania LC320SS8 32"
Sylvania C6432TE 32"
Sylvania C6432TD 32"
Sylvania 6632LG 32"
Sylvania 6632LCT 32"
Sylvania 6432TFY 32"
Sylvania 6432TF 32"
Sylvania 6432TE 32"
Sylvania 6432TD 32"
Sylvania 6432GG 32"
Sylvania 6432FE 32"
Posted on Oct 19, 2008
pineworks
  • 4293 Answers
SOURCE: error 0xd05d010d reset power
Hi there
0xd05d010d
Solution one: Reset the product
1. Without turning off the product, disconnect the USB cable from the rear of the product.
1. Remove the cartridges from the product.
2. Wait for the 'Insert Cartridges ' message to display on the control panel.
3. Disconnect the power cord from the back of the product.
4. Wait 60 seconds.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
6. Reinsert the cartridges, and then close any open doors on the product.
7. If you receive a prompt to print a calibration page, do so.
8. Reconnect the USB cable to the rear of the product, and then try printing again.
9. If you have completed all the steps listed above and are still experiencing a problem, you need to service the product.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 01, 2010
Testimonial: "still need to service"
Raditronic
  • 196 Answers
SOURCE: todos los botones del tv se revuelven ejemplo el
Cuando el tv te hace eso es que tiene uno o mas de los botones malos (tact switch), te recomiendo los cambies todos y se resuelve el problema.es defecto lo hace mucho los televisores RCA tambien.espero esto te ayude.
Posted on Apr 21, 2010
mariolands
  • 2296 Answers
SOURCE: en la pantalla de mi
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink absorber replacement, if you want your printer to work again. There are two ways to reset the Canon MP printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using MPtool Software to reset Canon MP Printer
Turn of printer then run mptool software this software automatically detect the printer.
Click reset main and reset platen button in the waste ink counter section.
If you want to reset the cartridge ink level, click reset black and reset color in the ink counter section.
2. Manual Reset of the printer
Turn off the Printers.
Press and Hold the button Resume/Cancel then press POWER button.
Release the Resume/Cancel button while keeping POWER button on press.
Press Resume/Cancel 2 times and then release all the buttons.
When the indicator recorded GREEN - click Resume/Cancel 4 times!
Turn off and On the Canon Pixma MP Printers. And your done.
Posted on Feb 07, 2011
Hola el problema que tengo es que la impresora copia muy oscuro y en un tomo chocolate quiera saber que puedo hacer en este caso gracias
Empezando, qu? impresora tienes? Si es un Deskjet y est?s escribiendo en modo de "color", deber?as ponerlo en modo de "black". Independientemente a eso, posiblemente tienes uno de los cabezales funconando incorrectamente de tal forma que el resultante de la impresi?n en vez de "black" sale marron.
Imprime los colores b?sicos para verificar cu?l es el color que causa el problema para reemplazar el cartucho o cabezal
Apr 18, 2015 | Office Equipment & Supplies
En el pa korg 500 de error aparece os lectura de archivos Que Se Puede HACER
Carlos Hi
despues de formatear el equipo todo tiene que volver como recibistes el pa 500 nuevo de fabrica
Mar 28, 2014 | Korg Pa800 Synthesizer
Hp officejet j3600 error del cartucho
Saludos
Mi nombre es Jose, es un placer intentar ayudarle para ello le recomiendo que limpies los conectores y mires bien cual es el cartucho que tiene problemas, de todas maneras puedes mirar este post.
Como solucionar error en cartucho impresoras hp
Oct 31, 2012 | Office Equipment & Supplies
Mi impresora HP 5610 tiene encendidas todas las luces marca un errror 0xd05d010d RESET POWER, que puedo hacer.. gracias
SOLUCION: Hola la solucion para la HP Officejet 5610 con ERROR 0xd05d010d es muy sencilla hay que resetear el Equipo lo cual se hace asi:
1. Desconectas el cable que va de la impresora al equipo
2. Luego desconectas el cable de poder de la impresora
3. Mantienes presionadas las teclas (ASTERISCO) * y (NUMERO) # y conectas el cable de poder a la vez.
4. Te sale unas preguntas de Idioma y pais las respondes y LISTO
BUENA SUERTE
Aug 23, 2011 | HP Officejet 5610 All-In-One InkJet...
Que puedo hacer mi control Panasonic DMR-ES45V no responde que puedo hacer o como consigo uno?
¡Hola
Realmente no puedo entender el problema de los dispositivos de Panasonic. Haga el favor de volver a publicar problema de sus dispositivos un poco explicado. S?lo tienes que explicar en espa?ol. Lo puedo conseguir. Ok
Jul 14, 2011 | Panasonic DMR-ES46VS DVD Recorder/VCR
Recientemente conecte la Pc a internet y al realizar las actualizaciones, en el reinicio en el momento de configurar las este win no arranca se apaga y prende en un ciclo que no acaba. no dispongo de disco...
Usted puede tratar de arrancar en modo seguro pulsando F8 durante el boods m?quina. Una vez en modo seguro se puede tratar de hacer una restauraci?n del sistema de la, en Inicio, Todos los programas, accessores Herramientas del sistema • Restaurar sistema. Si esto no funciona, entonces usted tiene que hacer una restauraci?n completa del sistema o la recuperaci?n del sistema en funci?n de su computadora. La mayor?a de los nuevos equipos le permitir? hacer una recuperaci?n del sistema pulsando una de las claves durante el arranque. Usted va a perder todos los programas y todo lo que est? en el equipo. Usted puede ser capaz de hacer esto sin tener que formatear el disco duro.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
Apr 04, 2011 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
Como puedo volver a registrar el tel si ya estaba en uso pero se borro el nip que ya tenia
primero tienes que presionar la tecla de registro/localizacion que se encuentra en la base por aproximadamente 3 segundos como minimo, luego la sueltas y le das en menu OK, luego configuracion OK, auriculas OK, Reg, auricular OK, y ahi te pide el PIN, son 0000 (cuatro ceros) OK, y eso es todo, tarda un minito o menos en registrarse, si tienes mas de un telefono, con cada uno de ellos tienes que hacer el mismo procedimiento y eso es todo, espero aun te sirva :)
Jan 02, 2011 | Siemens Gigaset A490 Twin Cordless Phone
El tv no enciende, solo lo intenta, se escucha un clikeo, el modelo es kdl-32l5000
He tenido el mismo problema varias veces, la tele parece completamente muerta. Es un problema con el modo de ahorro de energía. Si la televisión no tiene señal de entrada en uno de sus canales hdmi o vga, entra en modo ahorro de energía, encendiendo la luz de stand-by. No he determinado en qué situación aparece el problema, pero creo que es cuando, estando en stand-by, se desconecta la alimentación. Para resolverlo, desconecta la televisión del enchufe, a continuación desconecta TODAS las entradas traseras de señal, audio, vídeo, hdmi, vga... todo. Espera unos segundos, enchúfala y escucharás un click. A continuación, debe encender normalmente.
Nov 23, 2010 | Sony KDL32L5000 32 in. LCD HDTV
Hola como puedo conseguir el manual de usuario lo he buscado por todos lados y no puedo yo compre esta maquina de segunda mano y me gaste todo mi capital ahrs no se como hacerla que funciones gracias...
Sin saber qué maquina tienes sería imposible decirte donde encontrar el manual. Qué marca es (brother, hp, canon, etc) y qué numero de serie? Tal vez asi te pueda ayudar a encontrarlo. :)
Aug 18, 2010 | Office Equipment & Supplies
No puedo ingresar a la pagina principal de internet ,,, en seguida me muestra error......y de ahi me da opciones de ..,depurar no eniar errores y enviar errores probe con todo y no tengo ningun...
restablecer su módem y router de Internet. hacer primero el modem y si esto no funciona entonces el router (si tiene uno). El restablecimiento de los medios desconéctelos y esperar 30 segundos y luego enchufe de nuevo pulg
Si esto no funciona llame a su proveedor de servicios de Internet.
Jun 20, 2009 | Microsoft Windows XP Media Center Edition...
20 people viewed this question
Clive
Clive
