SOURCE: HDR-HC1 power keeps cycling
I had this exact problem, and the cycling would stop after about 30 sec. and then function properly. I believe a circuit was confused, mainly because I used an older battery and let it run out till the batt was dead - accidently - and when I put in a fresh batt, it no longer cycled and works perfectly to this day.
Now if I can get my computer to recognize the camera via firewire, I'd be golden.
SOURCE: i have a sony handycam hdr-cx7. I am able to
ok, when you have a High def camcorder like this one it only holds Memory sticks... at the end when you connect the camcorder to the computer the memory stick is recognized aswell for the still images, but the videos are not becuase the format of the videos are AVCHD, wich is just compatible with certain softwares, the camcorder comes with the software it is called "Picture Motion browser", if you dont have the disk you can download it from here http://esupport.sony.com/US/perl/swu-list.pl?mdl=HDRCX7, software is compatible with Windows XP and Vista OS but not for Macintosh ok!. Once you connect the camcorder the " USB Select" or " USB connect" will come up, so you will select it and once the software is installed it'll do everything for you.
Hope this would be helpfull.
If you have problems just let me know i work for Sony camcorder support.
SOURCE: looking for user manual sony HDR XR200 video
You can download the required manual from:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=HDRXR200V
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
SOURCE: sony hdr-cx7 image jitters when the cam gets hot
one fix is turning off steadyshot then try putting the camcorder upright(the lens pointing up) for few second until you see the video stabilize, then use as normal but the camcorder will jitter again if handle it roughly. This is just a workaround, i still dont know why it happens, need to send it for repair soon.
