Johan, Below are links to your model where you can access,manual,instructions and get support. Press the helpful button and follow me on fixya for more tips and info.
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
hi there, I'm sure you can find it at the back casing fronting the screen. It has this box casing and you can see a glass prism. I also insert an image of JVC lamp. hope this help, please rate and vote
Good Day,
To get the Lamp part number TS-CL11OUAA, around $200.00 cost, 1-800-252-5722/ www.jvc.com.
To replace: The Lamp will come intructions. It is very easy to replace if you have a phillips screw driver.
Turn tv off and unplug it. Take the access door off either side of the tv. Use a dust cleaning tool like a swiffer with an extension (or make one). Clean off lens (most likely the problem). I have the same thing that happens to my JVC 61". You can use a vacuum with extension if your VERY careful.
The POWER LED and LAMP LED are blinking alternately. • It may be a malfunction that the fan is locked or the temperature has increased. The POWER LED and LAMP LED are blinking rapidly simultaneously. • The lamp may not have been installed correctly, or it may be due to a malfunction. • The lamp door may not be closed correctly.
The LAMP LED continues blinking • It may be a malfunction of the internal electrical circuits
