Sounds like a drain hose or pressure switch hose is loose. Is the water leaking visible on floor?
Testimonial: "They water is quite visible almost immediately yet some water does make it to the tub. What water does make it to the tub drains when shutting the machine off. This is a top loader and quite old."
SOURCE: kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
SOURCE: leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
SOURCE: kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
SOURCE: Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Testimonial: "Thanks! Very helpful."
SOURCE: Kenmore 90 series heavy duty super capacity plus
If your TOP LOADING Whirlpool manufactured washer (Kenmore) is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Btw, thank you for the the quick response! I apologize for responding to your response in the testimonials section. How do I reply back to you if further discussion and or final outcome needs more postings??? The comment option was the only other way I can find for a reply. Thanks again !
Comment section is where to post follow up responses.
Only now do I see that! Thank you!
In addition to the comment posted in the "testimonial", I have extremely limited work space when It comes to removing the entire cabinet. Or the back panel for that manner!
SO, in an effort to avoid any unnecessary disassembly it was decided to simply prepare for a flood by sandbagging...(lol, JK) LAYING TOWELS AROUND THE PERIMETER, and being sure TO UNPLUG THE BEAST!! Make it a quick assessment to dump a semi small amount of water into the basket to see if the river flowed unassisted. Judging by the quick water flow to the floor and the sound that went with it, it just seemed logical as you suggested, that it was either a detached or cracked hose, or a huge hole "somewhere since I am unfamiliar with the schematics or actual way these things function. Needless to say IT GUSHED in MILLISECONDS of adding the water to the basket as if bypassing any designs meant to slow or contain the flow...
After tilting the machine on its side...to continue for an answer, It was quickly diagnosed as A HUGE HOLE in the bottom of the plastic outer tub that surrounds the outside of the basket. It was actually one of the plastic fins on the outer side bottom that must have been weighted down and contacted the metal spring frame thinging from an overload of stuff. That would be my guess...who really knows, she's gone,,,ssniff
21 gun salute to a beast of a workhorse that lasted 35 years plus! We'll miss 'er. Lesson learned...DON'T OVERLOAD!! Cause you don't know what you got til it's gone!
Thank you for your thoughts AND THIS SERVICE! It motivated me to investigate and hope this post can assist others in similar situations. MAY
KENMORE MODEL # 110.28824791 TOP LOADER...
MAY SHE REST IN PEACE!
35 years. You did well!
