SOURCE: Can you cook hamburgers and pork chops on the
There should be a drip pan already but remove the griddle and line it with aluminum foil that way you can just roll up the foil and throw away and you don't have to clean the drip pan. If you cook pork you need to cover with a lid and you want to make sure you get the meat hot enough to be safe, get a thermometer from Wal Mart and it will have a probe and the temp the meat has to be in order to be safe. Chicken is 160 beef is 140 and I don't eat pork and don’t know the exact temp for it but the problem will have it on it. If this helped please rate me.
SOURCE: The bottom heating element in
i would not trust it there is chemicals inside the heating element along with metal particals that you can get in your food... sorry ,but better eat out tonight.... good luck to you...
SOURCE: what tempt should pork chops be cooked at
You should cook them on at least 350 degrees in the oven for at least 30 minutes, depending on the size. Just keep checking them. Frying them is another option if you are more comfortable doing so. That's how I like to cook them.
