The EH0 error indicates a problem with the incoming voltage or the power supply or wiring inside the dryer. If there has been a problem with the electricity coming into your home (brown out or similar), the error will resolve when the power company fixes the issue. Otherwise the control board is not receiving the expected power from the power supply.
First unplug the dryer or shut off the power at the circuit breaker. Unplugging the dryer for at least 30 seconds will reset the error message. If you can, plug another appliance into the outlet and check if that works. If there is a wiring fault, get an electrician to check the outlet and wiring.
If the problem is inside the dryer, the power supply, the control board and the wiring to the control board will need to be checked. There could be a loose wire, a broken wire or a spot where the insulation has been damaged and two wires are touching. Check all of the wiring harnesses where groups of wires plug into the control board. Replace or fix any damaged parts or wires. The parts diagrams are available here: https://www.ransomspares.co.uk/parts/brands/electrolux/tumble-dryers/edc2086glw%20(91609724100)/ . If the dryer is under warranty, contact Electrolux to have the unit serviced.
I hope this helps.
SOURCE: Hi,
First of all is the machine doing anything it should not be.That alarm code does not exist on our system,the closest is EH1 and this relates to Power supply problems or a faulty PCB.To cancel press and hold the start/pause button and the nearest option button for about 5 seconds,now turn the programme knob to position 10 then hold in the start/pause button and option buttons again till alarm disappears and E00 is showing.Then turn dial to 0 then back to position 1 then back to 0 to cancel operation.
Hope this helps.
