Freezers Logo
L
LVan der Westhuizen Posted on Jan 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset my devy upright freezer? Model DUF281 F60312NE
Marvin
Level 3:
Top Expert:
  • Master 85,242 Answers
  • Posted on Apr 02, 2019
Marvin
Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29025074
Points
266281
2answers
Defy freezer duf281- how do you resolve flashing temp with red exclamation mark
Freezer too warm. Here is the link to the manual and its troubleshooitng section starting page 20: https://manualzz.com/doc/6492658/defy-f325-upright-freezer-duf-281-owner-manual
If not a matter of door being left slightly open or hot food being inserted or freezer recently being activated, one pursues other possibilities:
Is the compressor running? It is hot? Is the water filter clogged? Does it have a bad switch? Look for reset switch: https://www.youtube.com/watch?v=XstbFK31Us0
Mar 01, 2022 • Freezers
Freezer shuts off when door is opened. Why does it do this?
The alarm and the temperature senor are both broken and need to be replaced for your freezer.
2answers
Red exclamation mark flashing defy eco duf281
It's a freezer. The temperature should be minus 18.C, yours is showing 0'C. It is telling you the freezer is 18' hotter than it should be.
https://www.defy.co.za/amfile/file/download/file/166/product/1996/
Jan 10, 2021 • Freezers
My freezer has power but is not cooling is there a reset
no, need more info, model serial and do you hear anything at all.
1helpful
3answers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
My freezer is stuck in defrost mode causing the alarm light to remain on
My freezer wouldn't run and I did find there was a reset button on the back of the freezer where the chord runs into the switch.
1helpful
Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
